https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Simulating Verilog-A and Verilog-D together https://designers-guide.org/forum/YaBB.pl?num=1393606153 Message started by mowiehowie on Feb 28th, 2014, 8:49am |
Title: Simulating Verilog-A and Verilog-D together Post by mowiehowie on Feb 28th, 2014, 8:49am Hello, Anyone could help me to find out how can I simulate Verilog-A and Verilog-D modules instantiated in the same schematic when using Virtuoso ADE ? Any tutorials ? Thanks, |
Title: Re: Simulating Verilog-A and Verilog-D together Post by Andrew Beckett on Feb 28th, 2014, 9:40am These are in the documentation. If using IC615 or IC616 (say), in the CIW, you can do Help->Virtuoso Documentation, and then expand "AMS Environment" and then "Virtuoso AMS Designer Environment Tutorials". The tutorial databases are at <ICinstDir>/tools/dfII/samples/tutorials/AMS - there are a number of gzipped tar files in there and a PDF. In particular AMSDInADE.tar.gz is a good place to start. The tutorials are in the same place in IC5141 too. Regards, Andrew. |
