Design >> High-Speed I/O Design >> pll chargepump one to one correspondence between static phase error and ref spur
https://designers-guide.org/forum/YaBB.pl?num=1395957957
Message started by yvkrishna on Mar 27th, 2014, 3:05pm
Title: pll chargepump one to one correspondence between static phase error and ref spur
Post by yvkrishna on Mar 27th, 2014, 3:05pm
Hi,
For chargepump PLLs the presence of up-dn current mismath or leakage from chargepump ouput would cause Reference spur and also static phase error.
However is there a strict one to one correspondence between static phase error and Ref. spur magnitude?
(which is independent of the cause  mismatch/leakage)
I see these expressions in many journal papers. The expressions (1) and (2) here look as if the total static phase error estimate is sufficient to calculate the total Ref. spur magnitude.
Is my understanding correct??
Thanks,
yvkrishna
