https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> Calibre with PSPICE netlist https://designers-guide.org/forum/YaBB.pl?num=1397597592 Message started by x.q.w. on Apr 15th, 2014, 2:33pm |
Title: Calibre with PSPICE netlist Post by x.q.w. on Apr 15th, 2014, 2:33pm Hello, Got a question for Calibre PEX tool. After PEX is done, the created Spectre netlist uses the net names from layout instead of from the input netlist. This causes trouble because the layout net names are randomly created and don't have meaning to me. How do i set it up so that it uses net names from the input netlist. The Calibre help document says in the Inputs > Netlist section, if source netlist is specified, then the extracted netlist should use names from this source netlist. But the result still uses the layout net names. I am using the PSPICE source netlist. Please help. Thank you! x.q.w. |
