https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> verilog-A syntax for a capacitor or resistor https://designers-guide.org/forum/YaBB.pl?num=1398906905 Message started by bigball on Apr 30th, 2014, 6:14pm |
Title: verilog-A syntax for a capacitor or resistor Post by bigball on Apr 30th, 2014, 6:14pm Hi: Does VerilogA have the same syntax as verilog_AMS? I'd like to add a capacitor and resistor to my verilogA modeling, is the following code correct? By the way, how do I add thermal noise to the resistor? Thanks. inout a,b; electrical a,b; parameter real r=4K from (0:inf); parameter real c1=200p from (0:inf); parameter real c2=6p from (0:inf); electrical int; capacitor #(.c(c1)) C1(a, int); capacitor #(.c(c2)) C2(a, b); resistor #(.r(r)) R(int, b) |
Title: Re: verilog-A syntax for a capacitor or resistor Post by boe on May 8th, 2014, 2:05am bigball wrote on Apr 30th, 2014, 6:14pm:
- B O E |
Title: Re: verilog-A syntax for a capacitor or resistor Post by Geoffrey_Coram on Jul 8th, 2014, 7:23am The syntax you've shown uses the Spice compatibility documented in Annex E of the Verilog-AMS LRM; that means, you are actually adding Spice capacitors and resistor, and the simulator should be including the thermal noise of the resistor, as it would for a resistor in its native netlist format. You could write your own module for the resistor and use white_noise to add thermal noise. |
