https://designers-guide.org/forum/YaBB.pl Other CAD Tools >> Physical Verification, Extraction and Analysis >> How to define Via/contact when transfer layout from old designkits to new one? https://designers-guide.org/forum/YaBB.pl?num=1401862125 Message started by Jacki on Jun 3rd, 2014, 11:08pm |
Title: How to define Via/contact when transfer layout from old designkits to new one? Post by Jacki on Jun 3rd, 2014, 11:08pm Hi, I am facing a problem with the Calibre LVS. I have my layout in old version of the design kits, but now I want to transfer it to the new version of design kits, the schematic simulation is quite good, but when I try to extract the parasitics, I have several problems. The one I cannot solve is the via/contacts. The error is "the via/contact is not defined". I don't know how to define the via/contact when transferring the old version layout to the new one? Anybody can help? Thank you. Jacki. |
Title: Re: How to define Via/contact when transfer layout from old designkits to new one? Post by Jacki on Jun 17th, 2014, 3:58pm I may find one possible solution, and that is to flatten the layout, then re-attach to the tech lib. It may work for the not defined vias. |
