https://designers-guide.org/forum/YaBB.pl Design >> High-Speed I/O Design >> termination resistance trimming https://designers-guide.org/forum/YaBB.pl?num=1402376834 Message started by neeru on Jun 9th, 2014, 10:07pm |
Title: termination resistance trimming Post by neeru on Jun 9th, 2014, 10:07pm Hi, I have notived in several PHY designs that the termination impedance is 50ohms. But there are usually digital bits to tune them. How does the tuning happen in production ICS? I guess they can't characterize each chip...... Thanks in advance |
Title: Re: termination resistance trimming Post by raja.cedt on Jun 9th, 2014, 11:59pm that is why people use digital/Analog Auto calibration circuitry.. |
Title: Re: termination resistance trimming Post by loose-electron on Jun 24th, 2014, 3:12pm http://www.teradyne.com/ http://www.ltxc.com/ and many others |
Title: Re: termination resistance trimming Post by bharat on Mar 23rd, 2015, 6:10am that is why people use digital/Analog Auto calibration circuitry.. How is that calibration done, by using some external resistance ? I have seen impedance calibration for TX but not for RX. Thanks |
Title: Re: termination resistance trimming Post by raja.cedt on Mar 24th, 2015, 4:43am They do for both TX and RX. All standards has limit on S11,S22..very difficult to meet if you don't have some kind of calibration. Not only from S11,S22 point of view but also from TX driver swing and current point of view also termination is imp... Some people does this with a tester burning E-fuse which saves some initial bring up time. Raj! |
