https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> CIC filter MATLAB Modelling https://designers-guide.org/forum/YaBB.pl?num=1402565130 Message started by Christoforos on Jun 12th, 2014, 2:25am |
Title: CIC filter MATLAB Modelling Post by Christoforos on Jun 12th, 2014, 2:25am Hello! I am modelling the decimation filter after a Sigma-Delta converter in MATLAB using the signal processing toolbox. The passband frequency is 10 Hz and the downsampling ratio is 512. As a decimation filter I am using the Hogenauer CIC filter. The filter is stable up to and including the 3rd order. From 4th order is becomes unstable. Also, when I look at teh zplane the poles of the filter are just outside or the unit circle. Can someone help me to fix this? Thank you! |
