https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> jitter measurements in Spectre/VIVA https://designers-guide.org/forum/YaBB.pl?num=1409697243 Message started by Shriram on Sep 2nd, 2014, 3:34pm |
Title: jitter measurements in Spectre/VIVA Post by Shriram on Sep 2nd, 2014, 3:34pm Hi, I am trying to compare the peak-peak and RMS jitter between HSPICE and Spectre. I see an option called "period_jitter" in the Viva calculator but I do not see any options for peak-peak or RMS jitter measurements. Could you suggest any option to use? thanks, -Shriram |
