https://designers-guide.org/forum/YaBB.pl Modeling >> Semiconductor Devices >> External Input Variable https://designers-guide.org/forum/YaBB.pl?num=1410830245 Message started by MMI on Sep 15th, 2014, 6:17pm |
Title: External Input Variable Post by MMI on Sep 15th, 2014, 6:17pm Hi, I am trying to use external input variable as an input to an RC circuit module to incorporate self heating effect in my model. Can anyone help me with this? What i am trying to do exactly is, i have a model in which i want to include an RC circuit module whose input or the source should be Power = V*I already exist in my model. I would highly appreciate any help regarding this. Thanks You. |
Title: Re: External Input Variable Post by Geoffrey_Coram on Sep 23rd, 2014, 2:17pm Is your model written in Verilog-A? You can measure V and I with dependent sources and get the product V*I, but it's a little tricky to get the updated temperature back into the model, if it's a built-in model in the simulator. If it's Verilog-A, then it's easy to do, and there are examples in a couple open-source models (Mextram, Hicum, etc.). |
Title: Re: External Input Variable Post by MMI on Sep 24th, 2014, 7:37pm Thanks for your reply. My model is written in Verilog. I will look into those models. |
