https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Monte Carlo Analysis Histogram https://designers-guide.org/forum/YaBB.pl?num=1413225272 Message started by zulqar on Oct 13th, 2014, 11:34am |
Title: Monte Carlo Analysis Histogram Post by zulqar on Oct 13th, 2014, 11:34am Hi All, I am designing a current conveyor and I am doing Monte Carlo Analysis(by varying width and length of transistor) for Current gain , voltage gain and Rx,Ry & Rz. I am using code as given below: Vdd 5 0 2.5 Vss 20 0 -2.5 Ib 0 2 100u vin 7 0 ac 1 sin (0 100m 100kHz) .print V(8) .ac dec 10 10 100g sweep monte=30 .tf v(8) vin M1.... M2.... .end Here v(8)/vin is voltage gain(beta) .I want to print its value for each iteration and then plot its histogram around mean value of unity . How can I do that ? If anybody could give some suggestion regarding this , I will be thankful. Thanks |
Title: Re: Monte Carlo Analysis Histogram Post by raja.cedt on Oct 13th, 2014, 1:12pm which simulator you have??? |
Title: Re: Monte Carlo Analysis Histogram Post by zulqar on Oct 13th, 2014, 10:13pm I am using synopsys HSPICE. |
Title: Re: Monte Carlo Analysis Histogram Post by zulqar on Oct 22nd, 2014, 11:39am I am attaching plot of voltage gain (beta) . If anybody could help me in plotting its histogram , I will be very much thankful . |
