https://designers-guide.org/forum/YaBB.pl Design >> High-Power Design >> High Voltage Switch https://designers-guide.org/forum/YaBB.pl?num=1413824174 Message started by bki on Oct 20th, 2014, 9:56am |
Title: High Voltage Switch Post by bki on Oct 20th, 2014, 9:56am Hi, i need a switch that connects 150V to the load. That means, if the switch is closed i have 150V on the drain side and 150V on the source side. Any idea, how can i realize this switch? Maybe is there a solution available on the market? As far as i know, the most Power MOSFETs only accept such high voltages only on the drain sides but not on the source sides. Please help! |
Title: Re: High Voltage Switch Post by loose-electron on Oct 20th, 2014, 4:34pm discrete transistors here right? what is important is the max Vds max Vgs and depending on the architecture of the transistors (a lot of discrete MOSFET's are not symmetric in their doping profiles) sometimes max Vdg give us a simple drawing of what you are trying to do and perhaps we can help. |
Title: Re: High Voltage Switch Post by bki on Oct 21st, 2014, 12:39am Attached is the picture. The problem is, i have a gate voltage of 5V. So, if Vgs is maximum 20V for example, it means that on the source side can be maximum 25V. correct? So i would need a transistor that has Vgs=155V, if the source should withstand 150V. correct? Does anyone know a suitable solution? |
Title: Re: High Voltage Switch Post by boe on Oct 21st, 2014, 8:54am bki, assuming Vcap < Vboost, the standard solution is a "floating voltage source", that drives the gate 5V above the source. - B O E |
Title: Re: High Voltage Switch Post by loose-electron on Oct 21st, 2014, 11:35pm look at the architecture associated with "high side driver circuits" commonly used in half bridge drivers and similar power transistor control circuits. |
Title: Re: High Voltage Switch Post by bki on Oct 22nd, 2014, 2:11am Vcap is -40V and should become 150V when the switch is closed. Isnīt there a simple solution to connect the 150V with the output? The High Side MOSFET concept seems not to be a solution. |
Title: Re: High Voltage Switch Post by loose-electron on Oct 28th, 2014, 10:19am loose-electron wrote on Oct 21st, 2014, 11:35pm:
Start by putting the above into search. |
