https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> question about ADC spectral analysis https://designers-guide.org/forum/YaBB.pl?num=1421471855 Message started by sun on Jan 16th, 2015, 9:17pm |
Title: question about ADC spectral analysis Post by sun on Jan 16th, 2015, 9:17pm Hi A matlab code for ADC spectral analysis is following: clear; afs = 1; % 1V full scale fs = 1e6; % 1MHz sample rate N = 2^11; % number of samples cyc = 67; fx = fs*cyc/N; t = linspace(0,(N-1)/fs,N); B = 10; % internal ADC resolution delta = afs/2^B; y = cos(2*pi*fx/fs*[0:N-1]); %quantize samples to delta=1LSB y=round(y/delta)*delta; s = abs(fft(y)/N/afs*2); sdb = 20*log10(s); sdb = sdb(1:N/2); % drop redundant half s = s(1:N/2); % drop redundant half f = (0:length(sdb)-1) / N; % frequency vector (normalized to fs) bx = N*fx/fs+1; As = 10*log10(s(bx)^2); %set signal bin to 0 s(bx) = 0; An = 20*log10(sum(s)); SNR = As - An; figure(1); plot(f,sdb); grid on; text_handle = text(0.3,-30, sprintf('SNR = %4.1fdB\n',SNR)); fft output data contain a lot of 0s, resulting -infs in the dB scaled spectrum. The SNR calculated from the quantized signal is 43.1dB, which is far from the expected 62dB. I don't understand above situations. is there any problem of quantization or fft? |
Title: Re: question about ADC spectral analysis Post by sun on Jan 18th, 2015, 1:15am Hi all, there is a bug in the code. noise power should be calculated by: An = 10*log10(sum(s.^2)); resulting SNR fit expected well. But I still dont understand why there are 0s in the fft results. Sun |
Title: Re: question about ADC spectral analysis Post by eternity on Jan 20th, 2015, 6:16am Is there any definite trend that you see in the appearance of zeros in the output array which is used to plot the spectrum Also its more readable if you plot a spectrum of 'continuous type' instead of dots. Eternity |
Title: Re: question about ADC spectral analysis Post by RobG on Jan 20th, 2015, 3:37pm I forgot why the zeros are there, but they are so it is not a bug in your program. I just add a small amount (like 1e-6) to the spectrum before converting it to dB. I don't think the zeroes are there in a real system that includes thermal noise. |
Title: Re: question about ADC spectral analysis Post by ywguo on Jan 23rd, 2015, 12:56am Hello Sun, Would you please plot with all dots connected one by one? Now those two plots are not discernible. I cannot find where is the signal in the first plot. What is the magnitude and frequency of the signal? Best Regards, Yawei |
Title: Re: question about ADC spectral analysis Post by sun on Jan 24th, 2015, 9:14pm Hi Ethernity I can not see any obvious trend. Actually, there are -infs between consecutive two zeros. Sun eternity wrote on Jan 20th, 2015, 6:16am:
Title: Re: question about ADC spectral analysis Post by sun on Jan 24th, 2015, 9:22pm Hi I got a perty spectrum after I add some noise before quantizing. In a real adc. device noise will dither signal. As you said, someone told me that there are zeros in the fft output. I'm also want to know how to explain this. Sun RobG wrote on Jan 20th, 2015, 3:37pm:
Title: Re: question about ADC spectral analysis Post by sun on Jan 24th, 2015, 9:28pm Hi Yawei There are -infs between zeros. I have no ideal how to plot data for all dots. The signal is 0dB at about 16.3kHz. Sun ywguo wrote on Jan 23rd, 2015, 12:56am:
