Design Languages >> Verilog-AMS >> Help with Jiles Atherton Model
https://designers-guide.org/forum/YaBB.pl?num=1428309610
Message started by edge44 on Apr 6th, 2015, 1:40am
Title: Help with Jiles Atherton Model
Post by edge44 on Apr 6th, 2015, 1:40am
Hi,
I found an article by Mark C Williams on Simulation and Modelling of Non Linear Magnetics.
There is a code written in Verilog on the Jiles Atherton Model, but I want a simple code to be able to produce a hysteresis curve through MATLAB.
Is there a way in which the code be redesigned? I tried but there are certain symbols or syntax that I am not familiar with.
I have attached the paper for the same.
Thanks
