https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Breakdown Voltage Diode https://designers-guide.org/forum/YaBB.pl?num=1430828746 Message started by bki on May 5th, 2015, 5:25am |
Title: Breakdown Voltage Diode Post by bki on May 5th, 2015, 5:25am The breakdown voltage of a Diode is 50V. So, if i add 150V to one terminal of the Diode and 190V to the other terminal of the Diode, the voltage drop across the Diode is 40V. Is that ok for the Diode then or is it already a Problem that the voltage on the individual terminals are so high (150V/190V) ? |
Title: Re: Breakdown Voltage Diode Post by loose-electron on May 5th, 2015, 10:13am for a discrete diode in a separate package (not integrated into an IC) the relative voltage (difference between the two connections) is all that matters |
Title: Re: Breakdown Voltage Diode Post by bki on May 6th, 2015, 2:00am and how is the case for an integrated Diode? |
Title: Re: Breakdown Voltage Diode Post by carlgrace on May 6th, 2015, 1:10pm bki wrote on May 6th, 2015, 2:00am:
It's the same in principle, but can be quite different in practice. You can run an IC off whatever voltages you wish, as long as the difference between the voltages you define as VDD and VSS is within allowed limits. The challenge here is that typically an IC is connected to a ground plane on a PCB so now instead of just a diode operating at elevated voltages you have a whole system floating. That can lead you to a whole world of hurt regarding proper grounding and EMI considerations (and that's just for starters). People do this, but you have to think it through. |
Title: Re: Breakdown Voltage Diode Post by loose-electron on May 8th, 2015, 4:27pm integrated diodes are actually multiple diodes in one package. You have the parasitic diodes (to substrate and things around the diode) to also be concerned with. |
