https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> variabe capacitor in hspice https://designers-guide.org/forum/YaBB.pl?num=1431377936 Message started by vahid on May 11th, 2015, 1:58pm |
Title: variabe capacitor in hspice Post by vahid on May 11th, 2015, 1:58pm hi i decide simulate this circuit in hspice but i can't modeling variable capacitor section the capacitors in this circuit change by move (capacitive accelerometer ) and Unfortunately i have no Enough information about veriloge if I understand correctly , i can use veriloge in hspice if you can write variable capacitor in verivlog i thank you verrrry much |
Title: Re: variabe capacitor in hspice Post by Geoffrey_Coram on May 12th, 2015, 10:40am How do you plan to simulate the motion of the cap plates? Verilog-A can support multi-physics simulations, where the position, velocity, and acceleration of the plates are unknowns of the system, and then the position is used to determine the capacitance. I think you probably want to go this route, but if you don't know what I'm talking about, you have some reading to do before you're ready for the next step. |
Title: Re: variabe capacitor in hspice Post by vahid on May 12th, 2015, 11:38am yes my goal is Use of capacitor plates movement to Calculate Acceleration in HSPICE also acceleration type is transverse comb that you see on pic my problem just write netlist for this section of circuit |
Title: Re: variabe capacitor in hspice Post by Geoffrey_Coram on May 13th, 2015, 8:29am I would probably write a Verilog-A model for the cap like: module varcap(t, b, x); and then instantiate it in the netlist as xcap1 top bot xpos varcap ... where "top" and "bot" are the electrical terminals, and "xpos" is a node that represents the position. You'll want to be sure to scale xpos (perhaps simply choose appropriate units) so that the tolerances are appropriate (eg, if the plates move in nanometers, then when you represent xpos as a voltage with vntol=1u, you completely lose all accuracy). I've put xpos in the netlist, so I can connect other elements to it; you could also try to put all the mechanical components inside the Verilog-A module. |
Title: Re: variabe capacitor in hspice Post by vahid on May 13th, 2015, 11:48am thx for your answer In order to simulate the transient response of the readout circuit, a pair of time-varying sensor capacitors are required. A simple varactor model is implemented in Verilog-A which produces a voltage-controlled capacitor. This model has four terminals, where two terminals are the capacitor terminals, and the other are the voltage input terminals. The Verilog-A model is built upon the following equation: C = C0 + CV Vin (4) Q = CVC (5) IC = dQ/dt (6) This model consists of a fixed capacitor C0, and a variable capacitor CV . The model takes in a voltage Vin as an input and provides a variable capacitor C. Note that VC is the voltage across the capacitor C. In this design, C0 is assumed to be 100 fF, CV is 1 fF, and Vin can be any time-varying voltage signal that controls the change in the output capacitance. now i can't write this verilog-a model and i dont know vin must be sin voltage or not? |
Title: Re: variabe capacitor in hspice Post by Geoffrey_Coram on May 15th, 2015, 11:48am Did you see the basic capacitor model here: http://www.designers-guide.org/VerilogAMS/basic-models/capacitor/capacitor.va |
Title: Re: variabe capacitor in hspice Post by vahid on May 15th, 2015, 2:39pm yes but i dont know how define and write Vi and c=c0+c1vi equation in veriloge and use it in hspice :-[ :-[ :-[ :'( :'( |
Title: Re: variabe capacitor in hspice Post by Geoffrey_Coram on May 18th, 2015, 7:14am What is "veriloge" ? |
Title: Re: variabe capacitor in hspice Post by vahid on May 19th, 2015, 1:09am excuse me : verilog-a * |
Title: Re: variabe capacitor in hspice Post by Geoffrey_Coram on May 19th, 2015, 11:09am Step 1: download the capacitor model; figure out the syntax to include it in your netlist, and run a simulation. |
Title: Re: variabe capacitor in hspice Post by vahid on Jun 13th, 2015, 2:08pm hii i write this verilog-a for variable capacitor and i test circuit in hspice but capacitor don't change While i expected capacitance change sinusoidal please help me `include "constants.vams" `include "disciplines.vams" module vccap(Cp, Cn, Vp, Vn); input Vp, Vn; inout Cp, Cn; electrical Cp, Cn, Vp, Vn; real C; parameter real C0 = 0; parameter real CS = 2.5p; analog begin C = V(Vp,Vn); I(Cp,Cn) <+ C * ddt(V(Cp,Cn)); end endmodule hspice test : .hdl vccap.va .options post=1 x1 1 2 3 4 vccap vi 3 4 sin( 0 1 500k) .tran 2n 500us .PROBE tran cap(1,2) cap(1) cap(2) .end |
Title: Re: variabe capacitor in hspice Post by Ken Kundert on Jun 14th, 2015, 11:34am Two things:
-Ken |
Title: Re: variabe capacitor in hspice Post by vahid on Jun 14th, 2015, 12:59pm Ken Kundert wrote on Jun 14th, 2015, 11:34am:
thx Bro |
Title: Re: variabe capacitor in hspice Post by rockypn on Oct 29th, 2015, 3:11pm I am trying to use PWL to get the curve for CV anyone has been successful in doing it ? |
