Modeling >> Behavioral Models >> OTA model help
https://designers-guide.org/forum/YaBB.pl?num=1439012873
Message started by michdundee78 on Aug 7th, 2015, 10:47pm
Title: OTA model help
Post by michdundee78 on Aug 7th, 2015, 10:47pm
Hi all,
I'm trying to model an OTA with the following parameters:
- gm
- output resistance
- compensation cap
- max output current
- limited output voltage range
how to properly model its frequency response and how to limit its output voltage?
If someone needs the code I have written till here I can share it.
thank you in advance.
cheers
