Simulators >> Circuit Simulators >> PSRR cadence
https://designers-guide.org/forum/YaBB.pl?num=1442945278
Message started by pekachoo007 on Sep 22nd, 2015, 11:07am
Title: PSRR cadence
Post by pekachoo007 on Sep 22nd, 2015, 11:07am
how to find PSRR of a voltage reference circuit in cadence, which has one input and two outputs.
Title: Re: PSRR cadence
Post by sheldon on Sep 23rd, 2015, 9:14pm
Is it two outputs like V1=1.25V and V2=2.5V or a differential output?
Post by pekachoo007 on Sep 25th, 2015, 9:57am
2 outputs 0.2 & 2 V.
Post by sheldon on Sep 28th, 2015, 9:17pm
Typically I use transfer function analysis for PSRR. In your
case, you run transfer function analysis twice, once for each
output. The advantage of transfer function analysis is that you
can use one analysis for VDD PSRR, GND PSRR, and CMRR,
by properly defining the sources in the testbench.
Post by pekachoo007 on Sep 30th, 2015, 3:28am
is transfer function analysis is xf analysis? what do you mean by properly defining the sources in the testbench.
Post by sheldon on Oct 5th, 2015, 7:56pm
You will need to include a voltage supply between gnd! and the
DUT, in order to capture, VSS PSRR. For the input, use the
ideal_balun and define differential and common mode input
sources.
