https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Obtaining the minimum value of an input port in noise analysis https://designers-guide.org/forum/YaBB.pl?num=1444995075 Message started by sunmus on Oct 16th, 2015, 4:31am |
Title: Obtaining the minimum value of an input port in noise analysis Post by sunmus on Oct 16th, 2015, 4:31am Hi, I am trying to write a phase noise model of an integer divider. The input and output ports are of type phase and is accessed using Theta. For example, Theta(out) <+ Theta(in)/ratio. In the testbench setup for noise analysis, I am giving a flicker+white noise input to the divider. I want to get the white noise (floor) value at the divider's input port (in). how can I get this value and assign it to a real variable inside the divider module ?? I would appreciate if someone can help me asap. Thanks, Sunil |
Title: Re: Obtaining the minimum value of an input port in noise analysis Post by Ken Kundert on Oct 18th, 2015, 9:27am You cannot. During a small-signal analysis, the models are evaluated in advance and linearized. They are not active during the small-signal analysis itself. -Ken |
Title: Re: Obtaining the minimum value of an input port in noise analysis Post by sunmus on Oct 19th, 2015, 10:11am Thanks Ken ! -Sunil |
