https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> $table_model($abstime, ...) is very slow in Cadence Spectre https://designers-guide.org/forum/YaBB.pl?num=1446218912 Message started by cheap_salary on Oct 30th, 2015, 8:28am |
Title: $table_model($abstime, ...) is very slow in Cadence Spectre Post by cheap_salary on Oct 30th, 2015, 8:28am I created custom RF signal generator from I_PWL_File and Q_PWL_File using Verilog-A $table_model() like following. Code:
However this signal generator is very slow when it is used in Cadence Spectre compared to using two "analoglib/vpwlf". Is it limitation of $table_model() ? |
