Measurements >> Other Measurements >> WaveView width measurement of a pulse
https://designers-guide.org/forum/YaBB.pl?num=1447777955
Message started by rioni on Nov 17th, 2015, 8:32am
Title: WaveView width measurement of a pulse
Post by rioni on Nov 17th, 2015, 8:32am
Hello,
I am using WaveView to measure the output width of a pulse.
My problem is that when I use the measurement tool and choose the Meter Y Level to be locked at 50% , the result width is not in the 50 % of Y Level (I attached a printscreen of it).
My question is should I uncheck the 50% option and move the Meter by hand in the middle of the height of the pulse?
Thank you.
Title: Re: WaveView width measurement of a pulse
Post by rioni on Nov 17th, 2015, 8:36am
To make it  clearer , what I suggest to do by hand is the printscreen bellow .
