https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Need some help with this code https://designers-guide.org/forum/YaBB.pl?num=1447989524 Message started by wandola on Nov 19th, 2015, 7:18pm |
Title: Need some help with this code Post by wandola on Nov 19th, 2015, 7:18pm I am trying to write some code for a digital circuit. module Processor(count,residue,out) input [7:0] count; input [4:0] residue; output [12:0] out; wire [12:0] mem, tmp1,tmp2,tmp3; reg [4:0] coeff = 5'b10110; assign tmp1 = count*coeff; assign tmp2 = tmp1 + residue; if (tmp1>mem) assign tmp3 = tmp2-mem; else assign tmp3 = tmp+coef - mem; assign mem = tmp2; assign out = tmp3; endmodule I am using cadence nc-verilog for the design. the error msg says if(tmp3 > mem): illegal operand for constant expression can anybody help with this? really confused... Or, how shall I manage this? |
Title: Re: Need some help with this code Post by Torq on Nov 23rd, 2015, 5:41am Hi, wandola! It seems, you sould use a multiplexer instead of if/else construction: assign tmp3 = (tmp1>mem) ? tmp2-mem : (tmp+coef - mem); |
