https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> How to read a *.log file into VerilogA? https://designers-guide.org/forum/YaBB.pl?num=1452794882 Message started by Jacki on Jan 14th, 2016, 10:08am |
Title: How to read a *.log file into VerilogA? Post by Jacki on Jan 14th, 2016, 10:08am Hello, I am quite new to VerilogA. Currently I want to read a .log file into VerilogA and use the transition filter. The file is just a lot of "0" and "1", and either "0" or "1" in each line. How can I read it correctly? I try to use fscanf(), but I get the syntax error. Could anybody help me to correct the error? // VerilogA for VerilogA, readfile, veriloga `include "constants.vams" `include "disciplines.vams" module readfile (clk, out); input clk; output out; electrical out, clk; integer pwmfileA; real hold; real pwm_A[0:1024]; genvar i, k=0; parameter real thresh=0.6; parameter tr=1n, tf=1n, dy=0; integer j=1; analog begin @(initial_step) begin pwmfileA = $fopen("./pwm_A.log","r"); // here report an error $fclose(pwmfileA); end for (i=0; i<1024; i=i+1) begin pwm_A[i] = $fscanf(pwmfileA,"%d",j); //here report an error j=j+1; end for (k=0;k<1024;k=k+1) begin @cross(V(clk)-thresh, +1) hold = pwmfileA[k]; V(out) <+ 1.2*transition(hold, dy, tr, tf); end end endmodule the reported errors are shown here: Error found by spectre during AHDL compile. ERROR (VACOMP-1149): "./veriloga.va", line 26: Genvar loop evaluation failed. Check whether `/usr/bin/perl' is available. ERROR (VACOMP-1816): Exiting AHDL compilation. Any comments are welcome. Thank you. Jacki |
Title: Re: How to read a *.log file into VerilogA? Post by Jacki on Jan 15th, 2016, 12:17am Hi, In fact, my question can be simplified to be "how to read a text file into a vector"? The text file has 1024 lines, each line is a binary data either "0" or "1". Thank you. Jacki |
Title: Re: How to read a *.log file into VerilogA? Post by Jacki on Jan 15th, 2016, 3:51am Problem has been solved. Thank you. |
Title: Re: How to read a *.log file into VerilogA? Post by Geoffrey_Coram on Jan 18th, 2016, 8:08am For others reading this post, you might want to mention how you fixed it. For my part, I suspect the problem is that you $fclosed the file in @initial_step, so that it was not open when you tried to $fscanf. |
Title: Re: How to read a *.log file into VerilogA? Post by Jacki on Jan 25th, 2016, 4:30am Geoffrey_Coram wrote on Jan 18th, 2016, 8:08am:
Hello Geoffrey, Thank you very much for your reply. The problem has been solved. The reason for the slow simulation is I define a very big array, and use this array to read in the data file. This array occupies a lot of memory. If I remove this array. The speed is fine. By the way, do you know how to read a read starting from the middle part? Currently I only know to read in a file starting from the beginning. For example: fileA = $fopen("./A.log","r"); $fscanf(fileA,"%b\n",hold); If I want to read in the data from some middle part in the file A.log, can you please suggest how I should do it? Thank you. |
Title: Re: How to read a *.log file into VerilogA? Post by Geoffrey_Coram on Jan 25th, 2016, 7:13am VAMS LRM 2.4 section 9.2 / table 9-2 says that $fseek is supported in the analog context, so I suppose it's just a question of whether your simulator supports it. |
Title: Re: How to read a *.log file into VerilogA? Post by Jacki on Jan 25th, 2016, 11:35pm Geoffrey_Coram wrote on Jan 25th, 2016, 7:13am:
Hi Geoffrey, Thank you very much. I will try it. |
