https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> a error about the 'always' process of verilog-a https://designers-guide.org/forum/YaBB.pl?num=1453219601 Message started by Big Data on Jan 19th, 2016, 8:06am |
Title: a error about the 'always' process of verilog-a Post by Big Data on Jan 19th, 2016, 8:06am does anyone know how to solve this error?(i'm using hspice2010): pvaE* Not support Verilog-D syntax!!! 'always' file "adc.va", line# 14 always @(posedge clk)begin |
Title: Re: a error about the 'always' process of verilog-a Post by Geoffrey_Coram on Jan 19th, 2016, 10:04am always is part of Verilog-AMS (or digital Verilog); it is not supported in Verilog-A. You could try using the cross event @(cross(V(clk) - vth)) begin |
Title: Re: a error about the 'always' process of verilog-a Post by AMS_ei on Aug 6th, 2016, 7:43am you can also use @(above(expr)) statement. Thanks. |
