https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> ring oscillator with differential outputs https://designers-guide.org/forum/YaBB.pl?num=1453274581 Message started by jovial on Jan 19th, 2016, 11:23pm |
Title: ring oscillator with differential outputs Post by jovial on Jan 19th, 2016, 11:23pm Hello everyone! I wish to design a ring oscillator of 250 Hz (without using inductors and capacitors ) with two differential outputs. But the phase difference between the two outputs should be exactly 180 degrees. Also I need the output DC to be 900mV. I am using 1.8V supply voltage. Can anyone suggest me some paper for the same?? |
Title: Re: ring oscillator with differential outputs Post by loose-electron on Jan 21st, 2016, 8:33pm you may want to go at a higher frequency and do digital divide down afterwards. lots of papers in the IEEE JSSC - start there. RIng oscillators John Maneatus that will be a good start point |
