https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> DNL's equivalent noise in ADC https://designers-guide.org/forum/YaBB.pl?num=1454606684 Message started by newroad on Feb 4th, 2016, 9:24am |
Title: DNL's equivalent noise in ADC Post by newroad on Feb 4th, 2016, 9:24am Hi, when we calculate the SNDR or ENOB in ADC, we add all the noise together, i.e., quantization noise, kT/C noise, DNL noise, etc. Let's say DNL is +/- 0.5LSB and LSB=1mV, what's its equivalent noise in terms of mV? Thank you. |
Title: Re: DNL's equivalent noise in ADC Post by DanielLam on Feb 6th, 2016, 2:11pm First, quantization noise is a misnomer. It is a quantization error (deterministic). Designers often say quantization noise because they assume it is white (typically > 3 bits). Second, I've never heard of DNL noise. So I don't think DNL noise exists. In my experience, you get the noise from the FFT chart. For the INL/DNL, you take a lot of samples. A lot of samples depends on the what resolution and confidence interval you want (papers have been published). For example, I took ~3.5 million samples for an 11b ENOB ADC for a 97% (I think) confidence interval. I don't think white noise sources affect the INL/DNL because they will average out. You just have to take enough samples. But the quantization error will remain because it is deterministic. I am assuming there are no other distortion terms besides quantization. Regards, Daniel Lam |
Title: Re: DNL's equivalent noise in ADC Post by sheldon on Feb 9th, 2016, 10:23pm Newroad, Think what you are trying to say with DNL noise is that device mismatch will limit the dynamic range. You don't need to calculate the DNL to capture that effect. Usually you look for ways to avoid statistical DNL simulations. If you have access to the Cadence support site, there is an ADC Verification Rapid Adoption Kit that describes how to calculate SINAD. It is not straightforward. Sheldon |
