https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> A Voltage Variable Resistor in ADS https://designers-guide.org/forum/YaBB.pl?num=1458586399 Message started by jade on Mar 21st, 2016, 11:53am |
Title: A Voltage Variable Resistor in ADS Post by jade on Mar 21st, 2016, 11:53am I dont know why but every time I try to something simple in ADS that I can do in LTspice in seconds it takes me hours of frustration and in this case I was unable to figure it out at all.. All I want to do is create a simple linear equation based f(x) resistor whose resistance varies according to the voltage x at another wire label (or port) and run it in harmonic balance. Thanks in advance for help in this. |
Title: Re: A Voltage Variable Resistor in ADS Post by jade on Mar 21st, 2016, 12:22pm I got something to work with the following SDD2P SDD2P1 I[1,0]=0 I[2,0]=(_v1)/2 C[1]= Cport[1]= Well the output of this is still only a current source, I wanted it to be a voltage dependent resistor so back to the drawing board. |
Title: Re: A Voltage Variable Resistor in ADS Post by jade on Mar 21st, 2016, 7:01pm .. |
Title: Re: A Voltage Variable Resistor in ADS Post by Geoffrey_Coram on Mar 24th, 2016, 1:21pm Can you use Verilog-A? (At one time, ADS used to require a separate license to run Verilog-A models; I don't know if this is still the case.) |
