https://designers-guide.org/forum/YaBB.pl Simulators >> RF Simulators >> Ndivider/phase detector PSS+Pnoise simulation strange results https://designers-guide.org/forum/YaBB.pl?num=1459339260 Message started by wandola on Mar 30th, 2016, 5:01am |
Title: Ndivider/phase detector PSS+Pnoise simulation strange results Post by wandola on Mar 30th, 2016, 5:01am I am trying to design a type-I PLL. I am running phase noise simulation for the ndivider and phase detector. However, I encountered a very stranger problem for both circuits. I setup different corners. (process corner + LT/HT + LV/HV). In total there are around 20 corners. The PSS/Pnoise simulations completed without convergence issues. However, the phase noise for most corners are very close (+/-1dB). But for some corners, the PN is very strange. It could be 20/30dB higher than those correct ones. I tried to run transient simulation, there was no obvious problem with the ckt behaviour. does anyone encounter this before. What has really happened.?? |
