https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Change Defaults of Cadence ViVA(Virtuoso Visualisation and Analysis) https://designers-guide.org/forum/YaBB.pl?num=1463059457 Message started by cheap_salary on May 12th, 2016, 6:24am |
Title: Change Defaults of Cadence ViVA(Virtuoso Visualisation and Analysis) Post by cheap_salary on May 12th, 2016, 6:24am I would like to change default settings of Cadence ViVA. For example, I prefer thick line as default. And I don't prefer Zoom Bar. For Cadence Wavescan, I can change some default setting by adding the followings into ".cdsinit". Code:
However, these are not valid for ViVA. How can I set default settings for ViVA ? |
