https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Bondwire Inductance & Pad Cap Modelling https://designers-guide.org/forum/YaBB.pl?num=1467214431 Message started by jdp on Jun 29th, 2016, 8:33am |
Title: Bondwire Inductance & Pad Cap Modelling Post by jdp on Jun 29th, 2016, 8:33am Hi, I want to model the Bondwire Inductance & Pad Capacitance that come to the picture when connecting Vdd, Gnd etc. from outside the IC. Presently, I am simulating my circuit (switched capacitor one) with a model as seen in attached schematic. Is this model okay to use? Problem faced is that the internal supply rail voltages are RINGING - and decoupling capacitors are of no help as the Vdd & corresponding Gnd are oscillating in phase..! Please suggest how to get rid of such ringing on internal supply rails. |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by Ken Kundert on Jun 29th, 2016, 9:10am http://www.designers-guide.org/Design/bypassing.pdf |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by raja.cedt on Jun 30th, 2016, 2:19am Hi- 1. Bond wire model you should get it from packing people, as a rule of thumb use 1nH/1mm with some seris resistance. I guess you have double bond, but please some mutual inductance also (~0.6). 2. Always do an Em sim for pad capacitance or calculate from metal cap density from foundry 3. . Add a small series resistance to the decap, Just add enough if it is more than enough decap is no more decap rather it is a resister, which will compromise supply noise. This is the reason why always foundries makes decap std cells with non minimal length. Best regards, Raj. |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by jdp on Jun 30th, 2016, 8:03am Thanks Ken, and Raja! Raja, one thing if you may please help me with. I am attaching a MUTUAL INDUCTANCE model for my bondwires (as suggested by you). Can you please check if it's okay? (as I couldn't get much reference on the web regarding usage of "mind"), also if the inductor DOT SIGNs are properly placed? |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by raja.cedt on Jun 30th, 2016, 3:48pm yah--double bond always will have +ve mutual coupling. If you want to enhance your understanding,may be the following book might be a good start. Electromagnetics for High-Speed Analog and Digital Communication Circuits |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by jdp on Jun 30th, 2016, 7:56pm So, in my previous schematic, I should add mutual coupling between ALL the inductors, right? Is a coupling coeff ~ 0.6 ok for all of them on average. Also, Thanks for sharing the book... |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by loose-electron on Jul 6th, 2016, 10:33pm what is the package? does a package and bonding model exist? |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by jdp on Jul 7th, 2016, 1:05am Hi loose-electron, Right now, I don't have any idea of what package I will use... I just want to gauge how my designed ckt might behave in the actual environment of pads & bondwires..and put in place some precautionary measure (like using a damping resistor in series with decoupling cap to reduce ringing in the supply lines) if possible! But, in the absence of a precise package and bonding model, is it anyway useful to design and use such damping resistors based on just an approx. model? :-? |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by loose-electron on Jul 8th, 2016, 11:48pm Your internal model includes no C inside the chip, thus the extreme ringing. Often under 100MHz you can design without the package model and survive. Otherwise target some plausible packages for the chip and get a suitable model to start with |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by jdp on Jul 9th, 2016, 1:50am Thank you so much Jerry for sharing insight from your experience :) it is really helpful information..! If you don't mind my naivety, can you please elaborate a little on what you mean by "...internal model includes no C inside the chip" - what Cap (and between what) are you referring to? |
Title: Re: Bondwire Inductance & Pad Cap Modelling Post by loose-electron on Jul 17th, 2016, 9:41am jdp wrote on Jul 9th, 2016, 1:50am:
Internal capacitance from power to ground |
