https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Nested loop stability requirement https://designers-guide.org/forum/YaBB.pl?num=1471606584 Message started by thomasross20 on Aug 19th, 2016, 4:36am |
Title: Nested loop stability requirement Post by thomasross20 on Aug 19th, 2016, 4:36am I know there are other topics touching on this but I never saw a definitive answer. If I have an amplifier with one master outer loop which is stable... and one inner loop... does the inner loop need to be stable or not? References and hand-waving explanation much appreciated! Thanks.. |
Title: Re: Nested loop stability requirement Post by Frank Wiedmann on Aug 19th, 2016, 5:37am No, the inner loop does not need to be stable. You can have a system that is open-loop unstable but closed-loop stable. See http://www.designers-guide.org/Forum/YaBB.pl?num=1294178255 for an example. |
Title: Re: Nested loop stability requirement Post by loose-electron on Aug 23rd, 2016, 10:42am Last I checked, stability is only a question for those systems in which feedback exists. No? Think about it. |
Title: Re: Nested loop stability requirement Post by Frank Wiedmann on Aug 24th, 2016, 12:18am "Open-loop" refers to the outer loop. Of course, the inner (unstable) loop is still closed. |
Title: Re: Nested loop stability requirement Post by thomasross20 on Aug 24th, 2016, 10:59am Thanks - I will check out the link you posted. FYI I have an inner loop and an outer loop which is closed. So you can have a system which is closed-loop stable (main outer loop) and have internal loops that are unstable... I never did manage to find a good paper on this. I'll check out the link.. |
