https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Do not use the `absdelay' analog operator in a conditionally-executed statement https://designers-guide.org/forum/YaBB.pl?num=1472538740 Message started by Rosh on Aug 29th, 2016, 11:32pm |
Title: Do not use the `absdelay' analog operator in a conditionally-executed statement Post by Rosh on Aug 29th, 2016, 11:32pm Hello, I am trying to simulate the following code Code:
However, the error states I cannot embed an "absdealy" statement in a conditional executed statement. Is there any workaround for this? Thank you, Rosh |
Title: Re: Do not use the `absdelay' analog operator in a conditionally-executed statement Post by Geoffrey_Coram on Aug 30th, 2016, 11:08am What are you trying to do?? What do you think happens on the "tout" terminal (port) when the cross event is not active? What you've written, if any simulator were to try to implement it, would say that you want V(tout), at the instant that V(utility) - V(ref) crosses 0, to be a delayed sample of V(dut) from 10n earlier, and otherwise there is no contribution to the "tout" port. That doesn't make any sense. |
Title: Re: Do not use the `absdelay' analog operator in a conditionally-executed statement Post by Rosh on Aug 31st, 2016, 8:12pm What exactly doesn't make sense here? If utility crosses a reference voltage, V(tout) should be a delayed version of V(dut)? How would I write such a statement then? Geoffrey_Coram wrote on Aug 30th, 2016, 11:08am:
Title: Re: Do not use the `absdelay' analog operator in a conditionally-executed statement Post by Geoffrey_Coram on Sep 2nd, 2016, 11:29am What happens if utility doesn't cross the reference voltage? Your cross statement only says what the model should do at the exact moment of crossing; you haven't said what happens for all the other timepoints of the simulation. |
Title: Re: Do not use the `absdelay' analog operator in a conditionally-executed statement Post by Geoffrey_Coram on Sep 2nd, 2016, 11:38am I would think you want something more like this: Code:
At the crossing, this captures a sample from 10n earlier, and holds this until the next crossing. But I don't know if you wanted a hold, or if you wanted the output to be zero between crossings, or if you wanted the output to be zero until a crossing, and after the crossing to track (a delayed copy of) the input. |
