https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> Transient Noise analysis in eldo https://designers-guide.org/forum/YaBB.pl?num=1474390922 Message started by ksnf3000 on Sep 20th, 2016, 10:02am |
Title: Transient Noise analysis in eldo Post by ksnf3000 on Sep 20th, 2016, 10:02am Hi, I am doing a transient noise analysis using eldo. If I specify, the option for number of simulations=100 and check on no nominal simulation, it should run 1 noisy run. So is this noisy run including all the noise sources? And if I uncheck it, it runs for a long time giving a different output. What exactly is their difference? Was the 1 single noisy run equivalent to the 101 runs? Thanks, \ksnf3000 |
