Modeling >> Behavioral Models >> [SOLVED] oneshot circuit or monostable multivibrator
https://designers-guide.org/forum/YaBB.pl?num=1475177011
Message started by Shahriar on Sep 29th, 2016, 11:23am
Title: [SOLVED] oneshot circuit or monostable multivibrator
Post by Shahriar on Sep 29th, 2016, 11:23am
Hi,
I'm new to veriloga. I'm trying to make a veriloga model for a one-shot circuit. The steady output will be low. It would trigger on both positive and negative edges of input and the output will stay high for a defined "pw" parameter.
I can't figure out how to code the output getting back to steady state after "pw" time has passed after an edge occurs in input.
Here's the code I've written so far.
Code:
// VerilogA for scratch_veriloga, oneshot, veriloga
`include "constants.vams"
`include "disciplines.vams"
module oneshot (trigger, oneshot);
input trigger;
output oneshot;
voltage trigger, oneshot;
parameter real vil = 0.5;
parameter real vih = 2;
parameter real thres = (vil+vih)/2;
parameter real vol = 0;
parameter real voh = 2.5;
parameter real td = 0.1n from [0:inf);
parameter real tt = 0.1n from [0:inf);
parameter real pw = 3u from [0:inf);
//parameter integer dir = +1 from [-1:+1] exclude 0;
real state;
analog begin
     @(cross(V(trigger)-thres)) state = 1;
     //can't figure out how to code that 'state' will go back to 0 after 'pw' time after cross event.
     V(oneshot) <+ transition(state?voh:vol,td,tt);
end
endmodule
Could anyone please tell me how I can do this? Or point me to an example?
Thanks.
Title: Re: oneshot circuit or monostable multivibrator
Post by Shahriar on Sep 30th, 2016, 9:56am
Found the solution myself here. http://www.designers-guide.org/Forum/YaBB.pl?num=1210828245
Code:
@(cross(V(trigger)-thres)) begin
           state = 1;
           next = $abstime + pw;
     end
     @(timer(next)) state = 0;
Title: Re: [SOLVED] oneshot circuit or monostable multivibrator
Post by Ken Kundert on Oct 1st, 2016, 5:00pm
Thanks for posting your solution.
-Ken
