https://designers-guide.org/forum/YaBB.pl Measurements >> Phase Noise and Jitter Measurements >> Derivation of jitter expression from phase noise https://designers-guide.org/forum/YaBB.pl?num=1484312974 Message started by vroy_92 on Jan 13th, 2017, 5:09am |
Title: Derivation of jitter expression from phase noise Post by vroy_92 on Jan 13th, 2017, 5:09am In Thomas Lee' book, 'The design of low noise oscillators', he derives the jitter after tau duration. Long term jitter can be defined simply as the limit when tau tends to infinity. (I have attached an image with this post; please see that). Can someone work out or point to me how the limit was solved when phase noise function becomes unbounded as ω tends to 0? |
