https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Telescopic ota and its CMFB amplifier https://designers-guide.org/forum/YaBB.pl?num=1485625960 Message started by cetinkayahkn on Jan 28th, 2017, 9:52am |
Title: Telescopic ota and its CMFB amplifier Post by cetinkayahkn on Jan 28th, 2017, 9:52am Dear All, I would like to ask you a question about a telescopic ota and its cmfb circuit as depicted in the figure, attached. In this configuration, I used it in a unity gain capacitive feedback. In typical condition, cmfb could set the output to the desired vocm value. When I applied an offset voltage to one of the input transistors, one output of the amplifier jumps down, and other jumps up. This means that DC stabilization is deteriorated. Why CMFB can not set the output in an offset condition? How could I correct it? Is it normal, or something is wrong in the circuit? I would like to wait for your sincere helps Regards |
Title: Re: Telescopic ota and its CMFB amplifier Post by ULPAnalog on Jan 28th, 2017, 11:05am Is it an AC coupled amplifier? (Did you mean Cin = Cf to achieve unity gain?) If so, how is the input common mode set? Do you have mechanism to get the DC negative feedback (through pseudo resistors or something) to fix the input common mode? Offset that you applied, is a differential signal so there is nothing cmfb can do. Perhaps it would help if you can post the feedback configuration. Thanks and regards |
Title: Re: Telescopic ota and its CMFB amplifier Post by cetinkayahkn on Jan 28th, 2017, 11:57am Dear ULPAnalog, Firstly, I thank you for your questions. I posted a more detailed schematic. The amplifier is in a unity gain capacitive feedback. I put a DC voltage source as depicted in the attached file. Actually, I thought that Vicm could be set by CMFB by mirroring the current on two diodes which was already in a negative feedback but it did not solve the offset problem. I simply model 2 mV offset, occurring in a mismatch condition. However, in the offset condition, CMFB does not work, one output slips down, and the other slips up. How could I set vicm in a way that could set output correctly even in a offset condition. I thank you very much for your helps. Regards |
Title: Re: Telescopic ota and its CMFB amplifier Post by ULPAnalog on Jan 28th, 2017, 12:20pm Ok. I believe your input to the opamp is floating at DC and hence the common mode is not being set correctly. Did you check the DC node voltage at the inputs of opamp (without the offset). They should read 0V. You can modify the circuit as attached and make the resistance large say 100G. Check the input common mode in that case again (of course if the gate leakage is large, then you will have a trouble, you might then want to reduce R and see). Apply offset and check the behavior. Bottom line is that the input common mode of the opamp needs to be set correctly. |
Title: Re: Telescopic ota and its CMFB amplifier Post by cetinkayahkn on Jan 28th, 2017, 3:12pm Dear ULPAnalog, Thank you for your directive answer. It helps a lot. The circuit is bias well now. I use resistors as you depict them in your figure. Those resistors biased the gate of the input transistor as vocm. Now, I would like to eliminate the tail current as depicted in the figure in this message. However, it is hard to guarantee the current flowing on each branch, and biasing with resistors in the same topology does not help. Since the gates of the input transistors are not set to vocm. Dear ULPAnalog, I hope you would like to enlighten how to bias a tailless pseudo differential amplifier :) Thank you in advance Regards |
Title: Re: Telescopic ota and its CMFB amplifier Post by ULPAnalog on Jan 29th, 2017, 10:22am You could redesign the input pair such that the nominal current it carries when the input common mode at DC is equal to output common mode as the resistive feedback forces that. Alternatively, you can use a configuration in which the input common mode can be set independent of the output common mode,say by adding resistors at the input of the opamp and tying them to say Vi,cm. One such configuration is shown in the paper "0.5-V analog circuit techniques and their application in OTA and filter design" by S. Chaterjee et al. Although it is for DC coupled resistive feedback OTA, you can extend it to your case with modifications. |
Title: Re: Telescopic ota and its CMFB amplifier Post by designerH on Mar 6th, 2017, 11:09am Dear AnalogULP, I thank you for your informative explanations. The paper was quite helpful to understand how to set the bias of the amplifier correctly. What is the difference between CT-CMFB and SC-CMFB? How are the Vocm and Vicm of an amplifier set by SC-CMFB, correctly, in process variation including mismatches. Since, in any process variation, CT-CMFB sets the bias point in skew. An MDAC of a pipeline ADC can be given as an example for that. I would like to thank you in advance for your reply. Sincerely |
