https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> root raised cosine filter parameters setting https://designers-guide.org/forum/YaBB.pl?num=1487041441 Message started by adnan on Feb 13th, 2017, 7:04pm |
Title: root raised cosine filter parameters setting Post by adnan on Feb 13th, 2017, 7:04pm hi i tried to use root raised cosine filter in cadence (rflib >> root_raised_cosine) but did not get the proper o/p. Following were the parameters: alpha over_samples group_delay frame_time numChipsOut i tried to apply this filter on 50Gb/s source being used for OOK modulation. can any one guide how to set these parameters correctly. Thanks |
Title: Re: root raised cosine filter parameters setting Post by Andrew Beckett on Feb 14th, 2017, 1:29am See essentially the same question that was posted yesterday here: https://community.cadence.com/cadence_technology_forums/f/38/t/36905 Andrew |
