https://designers-guide.org/forum/YaBB.pl Modeling >> Behavioral Models >> writiing verilog -a time data to file https://designers-guide.org/forum/YaBB.pl?num=1488233629 Message started by openloop on Feb 27th, 2017, 2:13pm |
Title: writiing verilog -a time data to file Post by openloop on Feb 27th, 2017, 2:13pm I need to find a command for Verilog -a that will let me write the time that a crossing event occurs. $realtime seems close, but how do I get this into a file for processing later? |
Title: Re: writiing verilog -a time data to file Post by Geoffrey_Coram on Feb 28th, 2017, 12:21pm openloop wrote on Feb 27th, 2017, 2:13pm:
You should use $abstime instead of $realtime, which is not officially supported in the analog context. You should be able to use $fstrobe or $fwrite to write to a file. |
Title: Re: writiing verilog -a time data to file Post by Ken Kundert on Feb 28th, 2017, 4:41pm With a crossing event, you should also use last_crossing along with cross to get the best accuracy. See time interval measurement for a template. -Ken |
Title: Re: writiing verilog -a time data to file Post by openloop on Mar 1st, 2017, 6:43am Thanks all for helping. |
