https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> simple question about antenna https://designers-guide.org/forum/YaBB.pl?num=1494837523 Message started by si9dan2011 on May 15th, 2017, 1:38am |
Title: simple question about antenna Post by si9dan2011 on May 15th, 2017, 1:38am Hi all, I would like to know, if a good performance Tx antenna is also a good Rx antenna. Assumed all Tx and Rx conditions are same. Thanks. |
Title: Re: simple question about antenna Post by cheap_salary on May 15th, 2017, 3:59am si9dan2011 wrote on May 15th, 2017, 1:38am:
Cosider "Reciprocity" |
Title: Re: simple question about antenna Post by si9dan2011 on May 15th, 2017, 8:56pm Thank you for your reply Cheap. So let say, if I tuned my transceiver antenna to which I found the field strength during the transmission is maximum, can I assume I will receive a good signal also? |
Title: Re: simple question about antenna Post by cheap_salary on May 16th, 2017, 6:27am Do you have very basic knowledge about linear circuit ? si9dan2011 wrote on May 15th, 2017, 8:56pm:
Cosider "Reciprocity" Surely understand "Reciprocity". |
