https://designers-guide.org/forum/YaBB.pl Design Languages >> Verilog-AMS >> Regarding issue with absdelta https://designers-guide.org/forum/YaBB.pl?num=1495975077 Message started by AMS_ei on May 28th, 2017, 5:37am |
Title: Regarding issue with absdelta Post by AMS_ei on May 28th, 2017, 5:37am Hi, I am trying to achieve electrical to real conversion using "absdelta". Here is my code: //code starts here///////// module elec2real(signal); input signal; electrical signal; real sig_vol; initial begin sig_vol = 0; end always @(absdelta(V(signal), 0.01)) begin sig_vol = V(signal); end endmodule //Code ends here/////////////// The issue is that when V(signal) is 0V, sig_vol is driven to -4.44089e-16 as shown in the attached file. Could anyone please explain me how can I resolve this issue? Thank you. Kind regards. |
Title: Re: Regarding issue with absdelta Post by AMS_ei on May 28th, 2017, 6:21am The waves of V(signal) and sig_vol is attached |
Title: Re: Regarding issue with absdelta Post by Ken Kundert on May 28th, 2017, 4:30pm What issue? Are you concerned with a difference of less than a fV? -Ken |
Title: Re: Regarding issue with absdelta Post by AMS_ei on May 29th, 2017, 8:48pm Hi Ken, Thank you for your interest I am bit concerned about its -ve value. I was expecting a +ve value (may be in the order of fV) but, it should be +ve. Is it possible to obtain that? Thank you. Kind regards. |
Title: Re: Regarding issue with absdelta Post by Ken Kundert on May 30th, 2017, 12:08am Simulators cannot provide the accuracy you are looking for. There is always a small amount of uncertainty in the result. -Ken |
