https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Problems when increasing the frequency in ring oscillator https://designers-guide.org/forum/YaBB.pl?num=1498951301 Message started by Abdallah Kamal on Jul 1st, 2017, 4:21pm |
Title: Problems when increasing the frequency in ring oscillator Post by Abdallah Kamal on Jul 1st, 2017, 4:21pm Why? When i increased the frequency the output distorted. The circuit works properly when the frequency is less than 1Ghz, when the frequency passes 1Ghz |
Title: Re: Problems when increasing the frequency in ring oscillator Post by Jacki on Jul 18th, 2017, 1:25am Hi, Your information is too little, and it is difficult to get a conclusion from the figure you attached. Generally when you increase the current in the ring oscillator, the frequency will be increased linearly (almost), but you need to consider if your ring oscillator is CMOS inverter, current-starving inverter or current-steering inverter with diode clamp based. The load capacitor is different, and you need to look at the settling time. |
