https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> a layout question about the inductor https://designers-guide.org/forum/YaBB.pl?num=1503656282 Message started by baohulu on Aug 25th, 2017, 3:17am |
Title: a layout question about the inductor Post by baohulu on Aug 25th, 2017, 3:17am hi, all I have seen a inductor, its layout is in the attachment. why the width of the inductor is narrower inside ? is there any benifit for this type ? thanks |
Title: Re: a layout question about the inductor Post by cheap_salary on Aug 26th, 2017, 3:33am To keep area where magnetic flux is crossed. |
Title: Re: a layout question about the inductor Post by baohulu on Aug 27th, 2017, 11:07pm you say the outside has both the input and output influx, thus need large area, thus wider metal width ? is there any paper describe this ? thanks |
Title: Re: a layout question about the inductor Post by cheap_salary on Aug 28th, 2017, 1:27am baohulu wrote on Aug 27th, 2017, 11:07pm:
Describe using correct terminologies. |
Title: Re: a layout question about the inductor Post by baohulu on Aug 28th, 2017, 4:10am what does the "magnetic flux cross" means ? if we see the screen as a plane, the magnetic lines of flux inside the inductor has two direction, one is towards the screen, and the other is leaving the screen, you said "cross" means both the two direction magnetic flux exist ? |
Title: Re: a layout question about the inductor Post by cheap_salary on Aug 28th, 2017, 5:31am baohulu wrote on Aug 28th, 2017, 4:10am:
Expression of "magnetic flux cross" is used commonly there. There is no input and output regarding flux. baohulu wrote on Aug 27th, 2017, 11:07pm:
Simply consider situation if inner width is not narrow with keeping outer diameter. |
Title: Re: a layout question about the inductor Post by baohulu on Aug 28th, 2017, 8:39pm in the plane vertical to the inductor ring , the magnetic line can be described as "in" and "out" two direction , though the magnetic line is continuous all the time. if the width of the inductor is opposite, the inside inductor ring width is wider than the outside ring width, the inductor can also hold the same area, or say, the same outer diameter, do you think the two type inductors have the same performance ? |
