https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Integrator Leakage (finite op gain) impact on 2nd order SDM? https://designers-guide.org/forum/YaBB.pl?num=1508264927 Message started by neoflash on Oct 17th, 2017, 11:28am |
Title: Integrator Leakage (finite op gain) impact on 2nd order SDM? Post by neoflash on Oct 17th, 2017, 11:28am The impact of integrator leakage on 1st order sdm is clear. Any conclusion on its impact on 2nd order SDM from leaky 1st and 2nd integrator? Regards, Neo |
Title: Re: Integrator Leakage (finite op gain) impact on 2nd order SDM? Post by jdp on Oct 28th, 2017, 11:19pm Due to leaky integrator, the low freq response of integrator gets affected (becomes flat from the expected -20dB/decade slope) - this consequently affects the NTF of the SDM, which also becomes flat instead of having 20dB/decade slope, so overall, the noise shaping gets afftected in low freq range...should be similar in case of 2nd order as well. |
