https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Fully Differential Amplifier and output common-mode voltage https://designers-guide.org/forum/YaBB.pl?num=1510262735 Message started by Anna901 on Nov 9th, 2017, 1:25pm |
Title: Fully Differential Amplifier and output common-mode voltage Post by Anna901 on Nov 9th, 2017, 1:25pm Hello all, I have a problem to understand fully differential amplifiers and also their CMFB. I learned from theory vout2-vout1=A*(vin2-vin1). But I don't understand, how would be the output signals of a FD-Amp with supply voltages of -1.7 V and 1.7 V and an output common-mode voltage of 0.8 V regarding the input signals, as attached? How high can be the gain? |
Title: 2: Fully Differential Amplifier and output common-mode voltage Post by Anna901 on Nov 9th, 2017, 1:31pm Regarding the steps of the inputs signals, I drew the output signals. The outputs of the input signals of 50 mV and 500m V would be 26*50mV=1,3 V and 1.7 V, respectively, if the supply voltages are -1.7 V and 1.7 V with a output common mode of 0.8 V. Is the output signals correct? |
Title: Re: Fully Differential Amplifier and output common-mode voltage Post by Frank_Heart on Nov 17th, 2017, 10:54am the ouput is clipped with Vin=500mV. -Frank |
