https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> BJT circuit: Resistor to Voltage Converter https://designers-guide.org/forum/YaBB.pl?num=1519092254 Message started by luoshuer on Feb 19th, 2018, 6:04pm |
Title: BJT circuit: Resistor to Voltage Converter Post by luoshuer on Feb 19th, 2018, 6:04pm Hi Guys I am not an expert in bipolar circuit design. Currently, I am working on the bipolar circuit, resistor to voltage converter, and looking for the help. External resistance ranges from 100 to 10K, output voltage is around +/- 100mV @ 40C from 100 to 10K. The output could be slightly off from the picture, and I am looking for a conceptual solution Many thanks indeed Suer |
Title: Re: BJT circuit: Resistor to Voltage Converter Post by A Kumar R on Feb 20th, 2018, 3:32am you have a negative supply in the system? |
Title: Re: BJT circuit: Resistor to Voltage Converter Post by luoshuer on Feb 20th, 2018, 9:28am Hi Kumar, I have VDD= 2V, GND=-1.3V Sorry, I didn't mention it earlier. Thanks Raymond |
Title: Re: BJT circuit: Resistor to Voltage Converter Post by Jacki on Mar 20th, 2018, 1:39am which kind of help do you need? a resistor to voltage converter seems like a resistive sensor, with the voltage divider and voltage buffer, you track the output voltage. I think if you want a good track, first your supply votlage should be quite stable, or else, you need a Vref. The bipolar transistor may help you to generate the Vref, maybe the buffer as well. The output voltage accuracy depends on the sensitivity requirement of your sensor. |
