https://designers-guide.org/forum/YaBB.pl Design >> Analog Design >> Order of the DAC is one bit more than that of a ADC in a delta sigma converter https://designers-guide.org/forum/YaBB.pl?num=1528797377 Message started by vroy_92 on Jun 12th, 2018, 2:56am |
Title: Order of the DAC is one bit more than that of a ADC in a delta sigma converter Post by vroy_92 on Jun 12th, 2018, 2:56am I have seen in some publications that the the order of the DAC in the feedback loop of a delta-sigma converter is one more than that of the ADC in the forward path. (for >1 bit ADCs). For example if the ADC has 10 bits, then the DAC has 11 bits. Any particular reason for it? |
