Simulators >> Logic Simulators >> how to reverse the signal order when create bus in irun results?
https://designers-guide.org/forum/YaBB.pl?num=1534617917
Message started by liletian on Aug 18th, 2018, 11:45am
Title: how to reverse the signal order when create bus in irun results?
Post by liletian on Aug 18th, 2018, 11:45am
HI all
How to reverse the signal order when you create bus? As you can see from the attachement, the signal order is from 0 to 7, I would like to have the bus from 7 to 0 instead.
Thank you,
Title: Re: how to reverse the signal order when create bus in irun results?
Post by deba on Aug 20th, 2018, 2:20am
While creating bus, it depends on the order of selection.
