Design Languages >> Verilog-AMS >> VerilogA - White Noise and Flicker Noise
https://designers-guide.org/forum/YaBB.pl?num=1571961615
Message started by saigoutham on Oct 24th, 2019, 5:00pm
Title: VerilogA - White Noise and Flicker Noise
Post by saigoutham on Oct 24th, 2019, 5:00pm
Hi,
I am going through the verilog A manual
http://www.lumerink.com/docs/VerilogA.pdf.
It says "The white_noise function is active only during small-signal noise analyses and returns 0 otherwise."
Could you please let me what are small-signal noise analyses in "Spectre" ?
What analysis should I use in "Spectre" to see that the effect of white_noise function?
Title: Re: VerilogA - White Noise and Flicker Noise
Post by Geoffrey_Coram on Oct 25th, 2019, 5:49am
Spectre's "noise" analysis will activate this function.
You should try running a noise analysis with a native resistor in Spectre, and then write a Verilog-A resistor and compare the results.
(Other analyses, like pnoise, will also show white_noise. But regular "noise" is the easiest to get started with.)
