https://designers-guide.org/forum/YaBB.pl Design >> RF Design >> RF Transceiver in Mobile Communication https://designers-guide.org/forum/YaBB.pl?num=1582017895 Message started by Pooja on Feb 18th, 2020, 1:24am |
Title: RF Transceiver in Mobile Communication Post by Pooja on Feb 18th, 2020, 1:24am Hello, I am looking for is how the mobile knows which frequency or band it is using for transmission and reception? for e.g. : I am texting somebody. first the signal will go through triplexer then modulation of the signal. after that filtering of signal will take place. then it will go through power amplifier and in the last, mobile antenna will transmit the signal. In this whole process how my mobile knows or reads which frequency or band or 2G/3G/4G network it is using for transmitting the signal? Thank you in advance. |
