https://designers-guide.org/forum/YaBB.pl Simulators >> Circuit Simulators >> INL/DNL of DAC using Monte Carlo Statistical Simulation in Cadence Spectre https://designers-guide.org/forum/YaBB.pl?num=1587074163 Message started by repah on Apr 16th, 2020, 2:56pm |
Title: INL/DNL of DAC using Monte Carlo Statistical Simulation in Cadence Spectre Post by repah on Apr 16th, 2020, 2:56pm Hello, I would like to do INL/DNL of DAC using Monte Carlo Statistical Simulation in Cadence Spectre. Is it a matter of plotting each Monte Carlo run as I would one run ? Then grab all the data, post-process ? I would like to do 50 runs using the PDK mismatch parameters - ie. See the effect of device mismatch on INL and DNL. Thank you. |
