https://designers-guide.org/forum/YaBB.pl Design >> Mixed-Signal Design >> Conversion Rate and Data Converters https://designers-guide.org/forum/YaBB.pl?num=1587852816 Message started by repah on Apr 25th, 2020, 3:13pm |
Title: Conversion Rate and Data Converters Post by repah on Apr 25th, 2020, 3:13pm I want to use Model Writer in Cadence Spectre to make verilog models of an ADC and DAC - 10 bit each. My ADC has a 2ns conversion rate - I set this in the ADC block settings. Both ADC and DAC are clocked at 1MHz. What should I set the conversion rate of the DAC to be and why ? |
